I got it to work fine with this plate if I didn't pick from the top surface of the THK bearing. I needed to pic from the side, ie the hole was hidden.
This bearing has been used on many models, with the multiple bearings on multiple plates all attached to the same rail. This was a similar case, and this plate did not line up with the others. At least for any of my assemblies, if the height was important so things needed to line up or I needed to use a 36mm offset in an equation it worked fine 🙂
Pete
