Inventor Forum
Issues with software not responding to mouse input placing a dimension.
3 REPLIES 3
NickHorton8970
305 Views, 3 Replies
Is they a known issue / bug when placing a dimension. Sporadically when I place dimensions get to the stage in the process where I am prompted to select additional geometry or dimension location. At this point I can move the pointer around the screen as normal but when I left click I just get a bell sound and nothing happens. I have tried to use enter and delete but nothing happens. The only solution I have found to move on is to ctrl - del and close the program losing any unsaved work in the process.
It only happens once every 20 or so sessions but I do need to get it fixed.
If it not a known bug, any ideas would be welcome.
3 REPLIES 3
CGBenner
in reply to: NickHorton8970
@NickHorton8970
What version of Inventor?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
NickHorton8970
in reply to: CGBenner
Professional 2021
Hi Nick,
I am not aware of a behavior like this. Please install Inventor 2021.1 update to see if it helps. Then try using Inventor Reset Utility (All Programs -> Autodesk -> Inventor 2021 -> Tools). Please note that all settings will be reset back to install default.
Many thanks!
Software Test Engineer
Technology Administrators
