Inventor 2016:
I have two parts mated together.
I change the length of one of the parts - I loose the flush mate between the two parts.
I have to find that mate edit them (change nothing ) hit ok. Then the parts re mate.
Why do you have to perform all of the steps outlined. The parts original mated parts should remain in tact.
I would appreciate someones time and perhaps outline a faster application. I mate parts together all day long and I am starting to talk to myself ....
Barzzy
I seem to remember Sheet Metal ends having this problem but it was around adaptivity, not just normal mates. In what what you modifying the part that the face changes? Simple Edit? Adding an additional Face? Normally when the face changes internal IDs the mate gets lost but in your case the mate is maintained, you just have to edit it for Inventor to re-establish it.
Also are you up on all SPs and hotfixes for Inventor 2016?
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
It should Rebuild for you automatically, but since it isn't, try Rebuild or Manage>Rebuild All.
Usually just the "local update" lightning bolt works for me but some I do a rebuild all.. One of those 2 ALWAYS takes care of it..
