Issues with Exporting IAM to NWD
BeKirra
Advisor Advisor
BeKirra
I can't figure out saving assembly to Navisworks NWD) with specified model state.
Here is my thread posted in Navisworks forum.
https://forums.autodesk.com/t5/navisworks-forum/how-to-save-assembly-with-specified-model-state/td-p...
Thanks in advance.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
James_Willo
Hi, I remember speaking to the Navisworks team about this, but it was quite a while ago. There's definitely limitations on what model states you can bring in. I will try and find out more for you.
James W
Inventor UX Designer
James_Willo
If you go to Global options and Inventor you can set it to use the last active model state.
'Last active representation'
James W
johnsonshiue
Hi! Try this to see if it works for the time being. Place the assembly to another Inventor assembly. Keep the top-level Model State in Primary. Activate the desirable Model State in the subassembly. Then export it to Navisworks.
Many thanks!
Software Test Engineer
BeKirra
Thanks.
It works although it is not what I am looking for.
It is better than nothing.
Hope I can see the function in the next Navisworks update or release.
Also thanks to @johnsonshiue.
It will work, but sorry, I don't prefer to create another assembly file.
X² + Y² = C²
James_Willo
Please post your request on the Navisworks forum.
Thanks!
James W
