Inventor Forum
How do I stop Inventor Auto selecting the last model i had open as the base view to add in a drawing
3 REPLIES 3
GPHFJPJS
189 Views, 3 Replies
Afternoon all,
When I am placing View reps onto a Drawing sheet in Inventor, each time I place a new base view, Inventor will automatically Try to select/ add the last model I had open as the new base view. (Which isn't normally a problem).
However as I work with large General arrangement models of whole site layouts, this forces me to wait for inventor to finish processing the GA view before I can use the search option to select the model I actually want to show. IE single parts.
I would normally just open a small part first before I start detailing on the Drawing so I don't have this problem, but if there is a way to turn this option off it would save me time.
Cheers.
Labels (4)
3 REPLIES 3
SBix26
in reply to: GPHFJPJS
What version of Inventor are you using?
I might suggest a different workflow that could help with this.  Instead of creating a new drawing from template, then placing a base view, do this:
  • in the model you wish to create a drawing for, orient the model to your desired base view
  • right click on the name of the part/assembly at the top of the browser and select Create Drawing View
  • Inventor will present the Templates folder for you to choose the template you wish to use; pick one
  • You will have the desired base view of the desired model on your cursor to place as you wish into the drawing format you have chosen
Sam B
Inventor Pro 2024.2 | Windows 11 Home 23H2
johnsonshiue
Hi! This behavior was added a while ago to enhance drafting productivity. The only way to stop it is to open another drawing (a drawing view cannot be created from a drawing file).
Many thanks!
Software Test Engineer
GPHFJPJS
in reply to: SBix26
currently using 2022, but this will change in a few months.
Not sure this would work as We do multiple sheet drawings, and this would require me to open each model as i place the view. (Have used this feature before, but found it was slower for me. )
Technology Administrators
