Message 1 of 9
- Mute
- Permalink
- Report
I have recently started learning Inventor. I am using Inventor 2020.
When I try to use Shell command on an object created after sweep command it does not work. Interestingly this sweep was created after sweeping a circle through a spline. When I tried to do the same by using an arc (through the arch button) instead of a spline it works without an error.
Would you please able to tell me what I am doing wrong? Is spline which is also used to create an arc and much more easier to use cannot be used here?
Thank you very much in advance!
