Inventor Forum
Issue with Revolve
7 REPLIES 7
Message 1 of 8
chris13
430 Views, 7 Replies
Issue with Revolve
chris13
I have a simple radius that is being revolved on the inside radius of a part.  The end point of revolved radius is 10mm from the edge of the part.  The axis of the revolve is the axis of the inside radius.  Once the revolve is completed, I keep ending up with a revolve that ends 8.5mm, rather than 10mm, from the edge of the part.  Can anyone see what is happening here and what I can do to remedy this??
The center of the inside radius and work plane for the revolved sketch are both offset 1mm from the plane of the part.
Thanks!
Chris
Issue with Revolve
Thanks!
Chris
7 REPLIES 7
Message 2 of 8
mluterman
in reply to: chris13
mluterman
Yeah, and when you turn it into a "Join" instead of a "Revolved Cut", it does show 10mm (.394). Take a look at that in your model...when you go through the steps, you'll see both the 8.5mm & 10mm "witness arcs" when you're in the command....weird. I don't have time  to look further right now.
Message 3 of 8
chris13
in reply to: mluterman
chris13
Yep, that's what I'm seeing...
Tags (1)
Message 4 of 8
mluterman
mluterman
When you make the middle solid (suppress Extrusion 2) and break all unresolved links, it does give you the correct result (at least for that 10mm entrance radius).
Message 5 of 8
chris13
chris13
So, I flipped the sketch 90 degrees and like magic, it came out fine.  Never was able to put my finger on why it was off.
Message 6 of 8
kacper.suchomski
kacper.suchomski
The Revolve circle and the element circle do not share a common axis. Mathematics 🙂
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Kacper Suchomski
Message 7 of 8
kacper.suchomski
kacper.suchomski
Kacper Suchomski
Kacper Suchomski
Message 8 of 8
kacper.suchomski
kacper.suchomski
You just have everything on one axis now.
When my video loads, you'll see that you didn't position the sketch correctly and consequently didn't keep the features of the model in line.
Kacper Suchomski
Kacper Suchomski
