- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Using Inventor 2023. I run the Drawing Resource Transfer Utility (the utility), but target file is not updated.
I start the utility, select our current template file as the source, I select all of the resources so they are transferred. I then select the target file. It then asks if I want to transfer, I select YES.
It goes through its cycle, but after its all done, the target is not updated.
The only thing I can see is at the end of the log, it has a line Save and Close where the target file is listed. But the status for this operation is SKIPPED (see attached photo).
Can anyone help me with this??
Thanks !
Chris
Link copied
