Issue with derive solids [ipt]
nsatheesan34D64
Message 1 of 8
nsatheesan34D64
Hello
I have ipt file created by a user and checked into Vault. I am trying to derive solids from the base part file. However, I am unable to deselect Solids to create the part I intend to work on. I am using Windows 11, and Acad Professional 2021. Any thoughts?
Replies (7)
Message 2 of 8
ampster40
That software does not exist.
Inventor Professional 2021 I suspect hehe.
Could you please share the file so that we take a look at it and see what could be going on?
Message 3 of 8
SBix26
Can you attach the multi-solid part here?  I can't think of a reason that Derive would not allow de-selection of solid bodies.
Sam B
Inventor Pro 2025 | Windows 11 Home 23H2
Message 4 of 8
nsatheesan34D64
Hi @ampster40 @SBix26
Please find attached the part. I am not able to deselect Solids in this case.
Message 5 of 8
SBix26
Change the Design View to Master, or at least deselect Associative.  For me the Derive dialog opens with the Isometric DV selected and the Associative button selected.  I can't select/deselect solid bodies while the Design View is associative, which makes sense.
Sam B
Message 6 of 8
James_Willo
Yeah as Sam says, this is usually related to the design view. Confused me for a while the last time I looked at it.
James W
Inventor UX Designer
Message 7 of 8
johnsonshiue
Hi! Derive Assembly works the same way too.
Many thanks!
Software Test Engineer
Message 8 of 8
nsatheesan34D64
Hi guys,
Thank you it worked. Much appreciated.
@johnsonshiue @James_Willo @SBix26
