Hello everyone, I'm hoping someone can help me with the current issue I'm facing. I am opening an assembly (top level) from vault, then using open on my sub assembly. The main issue is I will update my sub assy, but the sub assy will load / appear different in my top level. I have checked the sub assembly into vault and have also tried updating / replacing the file and it holds the same appearance. Other odd thing to note is the error when measuring the sub assy in the top level. Hopefully I have explained this well enough, please let me know if more information is needed to help solve this issue.
Thank you all verry much, Don.
@elliottdLAYWC
Hello, Don & welcome! Thanks for your question and the video. Are you referring to the appearances that are applied in the sub-assembly being different than the appearances (colors) as they look in the top level?
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Hi Elliot,
I seems that there are two sets of the files, though they are named the same. However, the behavior does not sound right to me. If possible, please share the files in zip that illustrate the behavior here or send it to me directly (johnson.shiue@autodesk.com). I would like to understand the inconsistent behavior better.
Many thanks!
