Inventor Forum
issue show part in assembly
27 REPLIES 27
Message 1 of 28
nzaem1992
955 Views, 27 Replies
1.jpgi have issue to show part in assembly .. there is transparency  in some parts put i do not want this transparency i tried to solve it but i can can not solve this issue .. any help please
27 REPLIES 27
Message 21 of 28
A.Acheson
in reply to: nzaem1992
If you have copied and isolated all the files from your original you can delete files that are not broken. Just be careful they are not your project files. This should bring down the file size. Only the <10 files that have the visual defect will be needed. Hopefully that won’t autocorrect before your done😂
Regards
Alan
Message 22 of 28
nzaem1992
in reply to: A.Acheson
i did this because i do not where is the issue ... if you solve the issue please tell me
Message 23 of 28
nzaem1992
i solved this issue by make copy of assembly but i do not know where is the issue .. but when i make copy there is point side of some parts what is this points ??3.jpg
Message 24 of 28
SharkDesign
That shows whether a part is fully constrained or not.
See this article:
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Inve...
  Expert Elite
  Inventor Certified Professional
Message 25 of 28
BDCollett
There seems to be a visual corruption with your assembly. It seems to be mostly where there is a thread but not limited to that.
I have seen some weird graphics corruptions before and I do not know how they got there and they could not be fixed.
If you zoom the extents of your assembly there is some concerning things happening. You have work planes all over the place and they are a long long way from your assembly.
Building everything in one huge assembly like this with very few sub assemblies and thousands of constraints is going to give you problems.
If you isolate just some parts the graphical errors go away so with trial and error you might find the problem but I suspect there is just too much going on in the assembly and it is causing a visual bug.
If you want to do views zoomed in on certain parts of the model, then turn the visibility of the other parts off.
This is your assembly when zoomed to extent, the main assembly becomes a dot.
Message 26 of 28
NigelHay
Is your part an imported STEP file? I've had similar trouble because all or part of the file was a surface model & translucent.
Message 27 of 28
SharkDesign
Think you've got more issues than just that part. I can't even view the model on my machine. I get the overview, but as soon as I rotate it everything disappears.
  Expert Elite
Message 28 of 28
BDCollett
in reply to: SharkDesign
If you use the home button he has saved it over the assembly but if you center the view it does what my screenshot shows and zooms out because there are work planes so far away.
