Is there any way of setting the Base Unit in a part to liquid ounces?
acanx21
acanx21
I saw that at the item level, you can set the Units to Liquid Ounce, but I have not been able to find a way to set it at the part level. If I was to get a part to the item level and change it to be liquid ounces, it still shows the quantities as Gallon/Each depending on what we set the part to be.
We have parts that we would like to have show up as ounces in the BOMs instead of Each/Gallons.
Thanks!
acanx21
Finally found the code that would set the parameter to be fl_oz.
Adding it on here in case anyone else is interested
Dim partDoc As PartDocument
Set partDoc = ThisApplication.ActiveDocument
' Get the UserParameters collection
Dim userParams As UserParameters
Set userParams = partDoc.ComponentDefinition.Parameters.UserParameters
Set oParam1 = userParams.AddByExpression("OUNCES", "1", UnitsTypeEnum.kOunceVolumeUnits)
