Is there a way to refresh all thumbnails?
SharkDesign
Mentor Mentor
Message 1 of 18
SharkDesign
I love the new feature in the BOM that allows you to export the thumbnails too, but I use a gradient background to stop eyestrain from staring at white all day. This prints a bit crap and makes the thumbnail harder to see.
If I change my background to pure white is there a way to update all the thumbnails in an assembly so they use the current background colour settings?
  Inventor Certified Professional
Accepted solutions (3)
Replies (17)
Message 2 of 18
salariua
You can try All Thumbs from here
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Message 3 of 18
SharkDesign
That sounds interesting, where is the download link for it?
James
Message 4 of 18
salariua
you need to send Thomas an email from the contact page here.
So let's just ask @Anonymous if this add-in works with existing files or for new files only?
Adrian S.
blog.ads-sol.com
Message 5 of 18
johnsonshiue
Hi James,
For individual file save, you can click on Option button in Save dialog. There you can control how the thumbnail for the given file will be captured.
Many thanks!
Software Test Engineer
Message 6 of 18
Curtis_Waguespack
Hi jameswillo,
Here's an iLogic rule you can run from the assembly, that will toggle the background color from your current to white, save the thumbnail, and then toggle it back to your original color settings.
I hope this helps.
Curtis
related link:
https://forums.autodesk.com/t5/inventor-forum/sketch-visibility-in-thumbnails/td-p/7149677
'get current color scheme name
oColorScheme = ThisApplication.ActiveColorScheme.Name
'get current color scheme background type
oBackGroundType = ThisApplication.ColorSchemes.BackgroundType
'Change to Presentation (white background)
ThisApplication.ColorSchemes.Item("Presentation").Activate
'set to use one color background type
ThisApplication.ColorSchemes.BackgroundType = _
BackgroundTypeEnum.kOneColorBackgroundType
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oDoc As Document
Dim oRefFile As FileDescriptor
For Each oDoc In oAsmDoc.AllReferencedDocuments
	ThisApplication.Documents.Open(oDoc.Fullfilename, True)
	For Each oSketch In oDoc.ComponentDefinition​.Sketches
		oSketch.Visible = False
	Next
	'set work plane visibility
	For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
	oWorkPlane.Visible = False
	Next
	'set work axis visibility
	For Each oWorkAxis In oDoc.ComponentDefinition.WorkAxes
	oWorkAxis.Visible = False
	Next
	'set work point visibility
	For Each oWorkPoint In oDoc.ComponentDefinition.WorkPoints
	oWorkPoint.Visible = False
	Next
	'set iproperty to use ISO view on save
	oDoc.SetThumbnailSaveOption _
	(ThumbnailSaveOptionEnum.kActiveComponentIsoViewOnSave)
	'save and close the file
	oDoc.Save
	oDoc.Close
Next
'Change back to original scheme
ThisApplication.ColorSchemes.Item(oColorScheme).Activate
'Change back to original back ground type
ThisApplication.ColorSchemes.BackgroundType = oBackGroundType
Message 7 of 18
SharkDesign
Well that was exciting!
It errors on library parts but not content center for some reason. Other than that it seemed to do the job.
Nice one!
Message 8 of 18
Curtis_Waguespack
Hi jameswillo,
Here's a quick update that adds a Try/Catch on the Save call, so if the file can't be saved due to library or read only status, it catches the exception, and just moves to the next file.
I hope this helps.
Curtis
	Next
	Next
	Next
	Next
	'try to save
	Try
	oDoc.Save
	Catch
	'catch error and do nothing
	End Try
	'close the file
	oDoc.Close
Next
Message 9 of 18
@salariua @SharkDesign Although it hasn't been updated in a few years and I'm not even sure it works anymore, you can download All Thumbs from here: https://drive.google.com/open?id=0B9vVYSYnP3lOWkFPWlQtVVh4Skk
It worked on new and existing files on every save. Browsing through a folder of parts where they all had different background colors for the thumbnail was way too much for my CAD OCD.
Let me know how it works for you if you use it. I'm considering updating it for the latest version of Inventor since I've gotten so much new interest in the app the last few months.
Message 10 of 18
SharkDesign
Thanks, but how do I use this once it's installed?
I can't find how to launch the dialogue.
Message 11 of 18
@SharkDesign since this is an older add-in, Inventor will block the add-in from loading by default. You need to first install All Thumbs and then make sure it's not blocked in the add-in manager. Also, check the boxes mark it as loaded and load automatically.
When you have no documents open, there will be a button on the "add-ins" toolbar for "All Thumbs". Open this and check the box to enable the app after you select your preferred options.
I just tested the app and it actually still works perfectly with Inventor 2018.
Message 12 of 18
SharkDesign
Closing all the documents first was the bit I hadn't done.
Thanks!
Message 13 of 18
Yeah sorry, it's a bit wonky. I know. I would make it a little more user friendly if I were to update it.
Message 14 of 18
SharkDesign
It mostly works but quite often gets stuck on the white background and doesn't switch back. Resaving it usually fixes it.
It also changes the background in drawings which is unnecessary, but I don't know how this is coded so you might not be bale to get away from that.
Other than that, it's brilliant!
Message 15 of 18
Thanks Curtis!
It was incredibly helpfull!
Message 16 of 18
K.TRYFONIDIS
Thanks @Curtis_Waguespack for this it works awesome. I have a slight problem with some long beams though, profiles, that due to length i guess i get some straight lines, check picture bellow:
Is there a way to change the perspective or the view to show it like bellow?
long beam can't tell the geometry.
Desired picture:
Thanks a lot in advance.
Message 17 of 18
Curtis_Waguespack
Hi @K.TRYFONIDIS
Here is a version that selects the XZ Plane, and looks at it before saving the part files. I know you asked for a perspective view, and this sets an end view, but this approach might work. If not we can likely set the camera view to an specific iso view instead of looking an origin plane. I'll try to post back an example of that later as well.
You might need to add some logic to help it know which parts to do this for, so that not all parts will have that view, but I think something like this example would be the way to go.
I hope this helps.
Curtis
	ThisApplication.Documents.Open(oDoc.FullFileName, True)
	Next
	Next
	Next
	Next
	Dim oDef As PartComponentDefinition
	oDef = oDoc.ComponentDefinition
	oDoc.SelectSet.Clear
	'select plane
	oDoc.SelectSet.Select(oDef.WorkPlanes.Item("XZ Plane"))
	Dim oCtrlDef As ControlDefinition
	oCtrlDef = ThisApplication.CommandManager.ControlDefinitions("AppLookAtCmd")
	ThisApplication.ActiveView.Fit
	oCtrlDef.Execute
	'set iproperty to use current view on save
	(ThumbnailSaveOptionEnum.kActiveWindowOnSave)
	'try to save
	Try
		oDoc.Save
	Catch
	End Try
	'close the file
	oDoc.Close
Next
Message 18 of 18
Curtis_Waguespack
Here is a version that sets the camera to use a bottom iso view.
	Next
	Next
	Next
	Next
	Dim cam As Camera = ThisApplication.ActiveView.Camera
	If Not cam.ViewOrientationType = ViewOrientationTypeEnum.kIsoTopLeftViewOrientation Then
		cam.ViewOrientationType = ViewOrientationTypeEnum.kIsoBottomRightViewOrientation
		cam.Fit
		cam.Apply
	End If
	'try to save
	Try
		oDoc.Save
	Catch
	End Try
	'close the file
	oDoc.Close
Next
