Is there a way to measure a parts silhouette area projected onto a plane?
Ashley_Norman
Ashley_Norman
I have a complex part/assembly I need to calculate the visible area from certain angles to calculate wind loading area and centre. Projecting all the geometry manually is too time consuming as this is a regular task. The silhouette feature doesn't capture holes through the part.
When I searched I found this was possible in Space Claim. Is there an equivalent in Inventor?
https://help.spaceclaim.com/dsm/6.0/en/Discovery/user_manual/measure_projected.html
CGBenner
@Ashley_Norman
Hello!  If you create an offset work plane and create a sketch on that plane, you can project only the geometry that you need to measure into that sketch, and then use that to take some measurements.
Chris Benner
johnsonshiue
Hi Ashley,
There is an indirect workflow to get the measurement. Create a 3D Sketch -> create the Silhouette Curve from the body based on the selected direction. Create a 2D Sketch on the ground plane. Project the Silhouette Curve to the sketch. Inspect -> Region Properties -> select the sketch profile.
Many thanks!
Software Test Engineer
