Is there a way to hide other sketches when you're editing a single sketch?
Message 1 of 13
Whenever I start a new sketch on a complex part, my previous sketches are all visible. This causes my current sketch geometry to snap to it and it's just way less tidy. Is there an option to disable this?
Replies (12)
Message 2 of 13
Turn the visibility off.
Message 3 of 13
Binga
Have you tried this:
RMB in the sketch that you want to turn off the visibility!
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Message 4 of 13
Binga
You can also try to turn off the visibility of all sketches in the tab View > Visibility > 2D Sketches, or simply pressing F10:
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Message 5 of 13
Curtis_Waguespack
Hi Binga,
It's very likely the View > Visibility filter is what is causing the issue. I typically do not recommend using this tool (much at all, but particularly at the part level).
Right-clicking and turning off the Visibility should solve the issue.
I hope this helps.
Curtis
Message 6 of 13
All of the replies so far are either to individually deselect "visibility" from each sketch or to press F10.
If I have lots of sketches It is very tedious to deselect the visibility of each one individually. Also, F10 only works when you're not in a sketch environment.
Is there some tool to only show the sketch you're working on?
Message 7 of 13
Curtis_Waguespack
Hi amarciniakTF6LQ,
It's a case of "pay me now, or may me later".
If you didn't right click and turn off the sketches when you were done with them, you will have this issue.
Using the View filter filters them, but as you've seen other tools toggle the filter off, and they all come back on.
To fix the issue you find yourself in at that moment, you can create an illogic rule and paste in this code and run it, and it will go through and turn off each sketch (as if you right clicked them).
In the future, do yourself a favor and right click the sketches and turn them off when you're done. Smiley Wink
I hope this helps.
Curtis
'set document
oDoc = ThisDoc.Document
'set sketch visibility
For Each oSketch In oDoc.ComponentDefinition​.Sketches
oSketch.Visible = False
Next
Message 8 of 13
PhetaDesignLink
ok the snarky remarks like "do yourself a favor and turn off the sketch when your done doesn't help" this guy asked a legitimate question .... it's irritating that when one is in a sketch one would need to leave that environment to filter out 2d sketches which, btw also turns off the visibility of the sketch one wants to see. WTF are you all unable to see this guys issue and the reason it's annoying or do you just like to say **** like that to piss people off? it's like going to the doctor and telling him something hurts when you do a particular thing and the doctor responding with "don't do that then" would that be the type of advice you want from an expert?
Hi amarciniakTF6LQ,
I hope this helps.
Curtis
'set document
Next
Hi amarciniakTF6LQ,
I hope this helps.
Curtis
'set document
Next
Message 9 of 13
PhetaDesignLink
THE ANSWER IS "NO!" YOU CANNOT TURN OFF ALL OTHER SKETCHES WHILE YOUR IN A SKETCH SO THAT YOU DON'T HAVE TO DIG THROUGH, HUNT AND PICK AMONGST ALL YOUR OTHER SELECTABLE BUT NON INTERACTIVE SKETCH LINES. THE ANSWER IS NO YOU CANNOT SIMPLY TURN OFF ALL THE OTHER SKETCHES SO THAT YOU CAN EASILY SELECT THE SKETCH LINE OF THE SKETCH YOUR WORKING ON WITHOUT SELECTING ALL THE OTHER SKETCHES THAT ARE LAYERED IN THE SAME RELATIVE POSITION. NO YOU CAN'T DO IT WITHOUT LEAVING THE SKETCH AND NO THE ANSWER IS NOT TO FILTER OUT 2D SKETCHES BECAUSE THAT FILTER ALSO TURNS OFF THE SKETCH YOU WANT TO EDIT... SO SORRY AND I'M SORRY THAT THIS COMMUNITY IS FULL OF SOCIOPATHIC INTROVERTS WHO CANNOT GLEAN YOUR PROBLEM FROM YOUR QUESTION THEY SIMPLY WANT TO BE RIGHT AND RESPOND SNARKILY .... I'M SORRY BUT .... NO YOU CANT. NOW THIS IS SOLVED.
This thread is marked as solved but it is not solved at all... you simply responded with an answer he wasn't looking for and he got tired of trying to explain what intelligent people who are modelers should be able to glean through understanding and inference.  I read through all the comments and absolutely none of you answered this mans question correctly. do you live in a cave and you understand why he's asking this question and then answer intelligently? ... apparently not.
Message 10 of 13
JDMather
@Anonymous wrote:
…. This causes my current sketch geometry to snap to it and it's just way less tidy. Is there an option to disable this?
Tools>Application Options>Sketch tab unselect the Autoproject options (except for the part origin - I leave that one on).
Message 11 of 13
Curtis_Waguespack
Hi @PhetaDesignLink ,
Welcome to the forum!
I assure you my remarks were not intended to be "snarky", and I'm sorry that you interpreted them that way, but judging from the tone of your reply I can't help thinking that you might be projecting a bit. Smiley Wink
Sorry that my past attempts to assist another was unsatisfactory, maybe I'll get lucky and do better next time. (<--- see that right there is a bit snarky Smiley Wink)
Again, welcome to the forum,
Curtis
Message 12 of 13
Curtis_Waguespack
....  I'M SORRY THAT THIS COMMUNITY IS FULL OF SOCIOPATHIC INTROVERTS ....
lol Smiley Happy ...
Message 13 of 13
johnsonshiue
Hi Phillip,
Based on your reply, you seem to have a lot of complaints about Inventor. For this particular issue, I think I know where the problem is. It indeed tricky to get the desirable behavior here. A few things. When you edit a sketch, Inventor rolls back the model to when the sketch was created. So, any dependent sketches and features should be invisible (or it will be a bug). But, parent sketches may be visible depending on how the parent sketches are leveraged.
If the editing sketch has direct or indirect dependency on the parent sketches, such parent sketches will be visible to show the source. As you can see, not all sketches can be made invisible on you edit a sketch. Certainly, there might be bugs leading to confusing behaviors. I am not aware of an option or a rule to change these behaviors.
BTW, please avoid typing all-cap letters in your posting. It looks as if you are yelling at people. Also, the forum runs on mutual respect. It goes both ways. We are here to help resolve some of your Inventor issues, not your personal issues.
Many thanks!
Software Test Engineer
