Is there a way to batch plot to pdf?
jblower
Message 1 of 8
jblower
I've got a model w/ 100 individual drawings.  Problem is I need a pdf copy in addition to the .dwg for each.  Any way to do a batch plot and crank them out rather than needing to do each one individually?
Replies (7)
Message 2 of 8
Waguespack_Curtis
@jblower What version of Inventor are you using?
Message 3 of 8
jblower
2021 PRO
Message 4 of 8
blandb
I have an ilogic rule that generates a PDF on every save of a drawing, so later my boss can bind them all to a single pdf later if he wants.
But have you looked into using the TASK SCHEDULER > Print Files > Add drawings > Options > choose pdf writer?
Autodesk Certified Professional
Message 5 of 8
jblower
No, I'll see if that works.
Message 6 of 8
Curtis_Waguespack
Hi @jblower,
You can give this a try.
Here is a link to a batch tool I created years ago that will allow you to select drawings and then run an iLogic rule to create the PDF
iLogic Drawing Batch Tool 2015.v.1.4.idw
I don't have Inventor 2021 on this machine so you will have to create and load the PDF rule into this file first by following these steps.
  • Open the batch tool file and create a rule called Create PDFs *** ( the exact name is not important but it must have *** on the end.)
  • Paste the code provided below into the new PDF rule and click the Save button.
  • Then save the batch tool. drawing file. (this will open the iLogic batch tool form)
  • In the form click the Refresh Rule List button.
  • Then select the PDF rule from the drop down list.
  • Now you're ready to use the batch tool to select the drawings and batch them.
oDoc =  ThisApplication.ActiveEditDocument
oPath = IO.Path.GetDirectoryName(oDoc.fullfilename) 'use this line to wrtie the PDFs to the same folder as the drawing
'oPath = "C:\Temp\My PDFs" 'use this line if you want to output the PDFs to a different folder
oFileName = IO.Path.GetFileNameWithoutExtension(oDoc.fullfilename)'without extension
oPDFPathandName = oPath & "\" & oFileName & ".pdf"
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oPath) Then
    System.IO.Directory.CreateDirectory(oPath)
 'Set the PDF target file name
oDataMedium.FileName = oPDFPathandName
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Message 7 of 8
jblower
That partially worked but for some reason all my drawings w/ assemblies cause IV to crash. And others saved in ACAD force me to save them in IV first even though they're IV dwg. Any idea why?
Message 8 of 8
Curtis_Waguespack
Hi @jblower
I couldn't tell if you were referring to an issue with the batch tool that I posted or the Task Scheduler.
If it was the former, you can edit the rule called Batch Rule and delete all the code and replace it with this version, which will open the file with deferred updates and will close the drawings without saving changes.
If Parameter("ActionList") = "" Then
MessageBox.Show("No rule selected to batch process.", "iLogic",MessageBoxButtons.OK,MessageBoxIcon.Warning)
Return
Try
ThisDoc.Save
Catch
End Try
oRUSure = MessageBox.Show("This could take a while, are you sure you want to:  " & vbLf & "   " & Parameter("ActionList") , _
 "Start Batch Process?",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
If oRUSure = vbNo Then
Return 'exit rule
'[ batch process the list Of files -----------------------------------------------------
If Parameter("Files_List") = "< No Files >" Then
MessageBox.Show("There are no files in the list.", "iLogic",MessageBoxButtons.OK,MessageBoxIcon.Information)
Return 'exit rule
Try
oTest = MultiValue.List("Files_List") 'check for list parameter
Dim invDoc As DrawingDocument
Dim oOptions As NameValueMap
oOptions.Value("DeferUpdates") = True
	i=0
	For Each oItem in MultiValue.List("Files_List")
		'open the indexed file, false opens the file without generating the graphics
		'invDoc = ThisApplication.Documents.Open(MultiValue.List("Files_List").Item(i), True)
		invDoc = ThisApplication.Documents.OpenWithOptions(MultiValue.List("Files_List").Item(i), oOptions, True)
		'run the rule
		iLogicVb.RunRule(Parameter("ActionList"))
		i=i+1
		If invDoc.FullFileName <> ThisDoc.Document.FullFileName Then
			Try
			invDoc.close(True) 'close the file skip save
			Catch
			End Try
		Else
	Next
Catch
End Try
MessageBox.Show("Batch processing files is complete.", "iLogic",MessageBoxButtons.OK,MessageBoxIcon.Information)
