How to change orientation of tubing run when placing initial node?
WillL84
WillL84
I'm trying to do some tubing runs. I made a new tube style for some pneumatic air hose we use. When placing the initial node in the run I can't figure out how to change the direction of the hose. It always wants to make the run go into the fitting instead of come out of it (see image below). You can see the red arrow goes the complete wrong direction.
After I place it it has some arrows for rotating the axes but that does nothing for the tubing direction. Thanks.
Windows 11 Pro 64-bit
Inventor 2025 (PDMC)
TITAN Computers C161
i7-11700K/32GB RAM/Quadro RTX A4000
A.Acheson
Hi @WillL84
What happens when you place each fitting and run the hose in between?
Regards
Alan
IgorMir
Press the Space Bar on your key board. It will reverse the direction of the fitting.
Cheers,
Igor.
Web: www.meqc.com.au
WillL84
Thank you!
