Is there a way to array a sketch feature along a path in a sketch?
chris
Advisor Advisor
chris
I'm trying to array a circle, (Orange), with equal spacing along a sketch path, (brown), in a sketch, is this possible?
JDMather
@chris
It is computationally less expensive to create a feature with that circle and then Pattern the Feature along the path.  Easier to update number of instances as well.
chris
@JDMather well for this example, that first "circle" would represent a circular piece of rebar, and each of the other circles would also be another circular rebar, with each circle being a different OD based of the spacing of those circles, so a simple feature pattern doesn't work for this example. But if Inventor gave us the ability to pattern along a sketch "within" the sketch, then my revolve would indeed create rings with different diameters. Is there a way to sub-divide a line or spline in a sketch or 3D Sketch? I need a way to equally space a user defined number of "circles" along a "blue" path, where each will be a different diameter. (see image). It was to do this on the bottom row of rebar, as they are all on the same plane, but the blue path presents a challenge that to the best of my knowledge Inventor is unable to accomplish, which is to pattern the circle along the blue line equally spaced?
kacper.suchomski
Hi
I don't think what you're asking is that easy to do.
Although a sketch element pattern along a sketch curve is not possible.
But that's not the end of your struggles - evenly distributing the elements along a curve will give a constant spacing along that curve - but not along a straight line, as you've shown.
Equal spacing in one direction, and equal spacing in several directions of a curve, are two different sets of desired effects.
Kacper Suchomski
chris
@kacper.suchomski  Yep, in order to get this one done I just dd the spacing manually, but this seriously needs to be added to Inventor. I can easily subdivide a line segment in Blender, Plasticity, MODO, Cinema 4D, seems silly that Inventor won't/can't do this.
johnsonshiue
Hi Chris,
The path-based pattern isn't supported in Inventor Sketch Pattern at the moment. You may either create a boundary patch of the sketch profile or extrude the 2D sketch as a surface. Then pattern the surface body along the path. Lastly, project the resultant edges to a new sketch.
Many thanks!
Software Test Engineer
