Is there a way to add the Inventor User Name to the Revision Table instead of using Author, Engineer, etc.?
chewy_robot
chewy_robot
I want to make it so when a user creates a new revision row in the revision block their name will automatically fill out who the revision was by. Currently, we have it set to Author which doesn't work as intended since the Author of the drawing may not be the one who is revising the drawing. I have no problems pulling the Author information. I am looking for some sort of option where I could select something along the lines of the "User" instead like found in the Application Options. That way, whoever creates the revision row in the revision block, their user name is automatically filled out. Is this possible? I looked around in the style library but I couldn't find what I was looking for. Any help is appreciated, thanks!
johnsonshiue
Hi! Unfortunately, it isn't available out-of-the-box. Maybe iLogic can help.
Many thanks!
Software Test Engineer
