is there a tool to calculate volume of a part?
Torben.pedersen
Torben.pedersen
hello there
How can I mesure the volume of a part in inventor?  is there not a tool for that, or am I forced to calculate it my self?
I hope this was helpfull.
Did I answer your question please accept this as solution.
if you liked my answer feel free to give me a Kudo 🙂
Replies (14)
salariua
Have you checked iproperties?
if it's a multi body then you can interogate each body in the browser with right click and choosing properties.
undefined
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
Torben.pedersen
it is not a ipart, so I don´t have the Iproperties, only properties. what do you mean about multi body?
It´s a cilinder, with a some details here then there
salariua
If you create it as a separate body then in the browser right under the part name (top level name) you have a folder Solid Bodies. Expand that and right click on your body to interogate, and choose properties.,
I ussually rename my body to Volume, or Water,etc. just so I can find it easier.
undefined
so if you use New Solid option in your extrude or revolve then you can interogate it individually.
undefined
Adrian S.
blog.ads-sol.com
salariua
if it's not a part, is it a surface ? you need to make it a solid with either sculpt, thicken...
is it an assembly? it must contain a solid body because you can only add cuts at the assembly level.
please explain or attach the file here.
Adrian S.
blog.ads-sol.com
SBix26
Every part has iProperties, no matter what.  If there is a solid body in the part, then the iProperties > Physical tab will give the Volume (you may have to click the Update button).
Sam B
Inventor Professional 2016 Update 2
Vault Basic 2016
Windows 7 Enterprise 64-bit, SP1
Torben.pedersen
it is a part just not a Ipart
JDMather
Let's try one more time -
EVERY part has iProperties. Period!
It does not have to be an iPart.
If you can't figure it out - attach your file here.
salariua
it is a part just not aIpart
no one said anything about iparts....the properties of a part are called "iproperties".
Adrian S.
blog.ads-sol.com
Torben.pedersen
thanks a lot 🙂
Calculate the volume of a steel vessel it's very simple, from iProperties, but Is there anyone here that can help me with the following problem:
I want to calculate the volume of a steel vessel after temperature material expansion. (1 degree). Is there any feature in inventor that gives you the volume depending of the temperature increase or decrease?
TheCADWhisperer
You should have started a new thread for this question.
Volume of material is different problem than volume of cavity within a vessel.
Derived Component with scale as surface body.
Close the volume and Sculpt.
Attach your file here if you can't figure it out.
Thank you for taking my question intro consideration, i will try to explain how clearly is possible what I want to calculate:
INTRODUCTION:
I have a steel vessel for kerosen storage with 1600 mm inner diameter and with dished heads. For this vessel i have to make a calibration plate. The tabel for the calibration plate must to have 2 rows: height  with a 5 mm iteration (mm) and volume of the storage liquid (liters). The vessel have 2 compartiments separated by a sheet plate with a height of 800 mm. As in the attached drawings, i already did this job, using the iproperties for every 5 mm of height. (attached table). This volume is obtained at a ambiental temperature of 15 degress C.
WHAT I WANT TO CALCULATE NOW WITH INVENTOR IF IT'S POSSIBLE:
If the temperature of the equipment (steel vessel) will increase with 1 degree, the steel will have a dilatation, so the diameter of the vessel will have a small change. I want to add at my existing tabel a new column with the volume for all iterations of height for the new diameter after material dilatation. I attached my initial drawing with volume from iproperties for every iteration of height and also a sample of the sketch how i calculated the volume for a height of 650 mm.
Thank you for your time and hope to hear from you soon !
I was wondering if you can convert the value from cubic millimetres to cubic metres? I'm making this massive thing but I choose the unit as millimetres instead of metres so do I have to make my behemoth of a thing again? Thanks for taking the time to read this.
TheCADWhisperer
@Anonymous wrote:
…. but I choose the unit as millimetres instead of metres …..
Did you use the correct number of millimeters?
Can you Attach your file here?
Tools>Document Settings>Units?
Do you know how to convert cubic millimeters to cubic meters?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
