You cannot accomplish that utilizing just the flange commands..
You can extrude that shape later but often times you will run into problems with the flat pattern command and getting accurate flat pattern dimensions.. So you have to decide whats important to you and what you can live with..
Quite a few have proposed workarounds from modeling the part in the as grooved material thickness to modeling it full material thickness and modifying the bend tables to get close to just including a note on the drawing about the grooving and not modeling anything to manually adding the vgroove to the flat pattern to more and more..
In general Autodesk Inventor does not really have a proven/reliable process for this somewhat uncommon practice.
A google search for "Autodesk Inventor V-grooving" will yield a bunch of posts/topics about it..
