Is it possible to make pure wire mesh using inventor
Message 1 of 42
Hi, Is it possible to make a pure wire mesh or net structure (without using any graphics texture) in any version of inventor.
If possible, please let me know the procedure.
Replies (41)
Message 41 of 42
dan_inv09
I should have read all the way through before I started mine.
Don't know if it's any different or even helpful in anyway, but, here it is anyway (roll down EOP).
Message 42 of 42
ampster40
interesting model Dan. I forgot how much fun it is to go thru models to see how they are created. Just dragged the EOP below each stage, one at a time, make the feature visible if needed and you can eventually go from point A to Z and figure everything out. I like your approach in figuring out the sweep each wire begins with but I'll have to take a bit more time to figure out all the extruded surfaces and how they were used to achieve this. Here's two methods now for the OP to consider - both would eventually cause some strain for Inventor depending on the length/final design I suppose.
