Is it possible to get flexible assembly status?
bwang-tecoustics
bwang-tecoustics
We can use flexible assemblies and set each assembly to a different setup. Say different extension for a cylinder. Is it possible to get the current extension of each cylinder?
James_Willo
I think the only way to do this is to add a sketch with a reference diameter so that when it moves the dimension updates.
James W
Inventor UX Designer
cidhelp
Hello @bwang-tecoustics ,
you can measure the distances or let iLogic do the measuring.
For iLogic: name a face in the cylinder-part and name a face in the piston-part.
Create a rule in the assembly to measure the distances between these faces:
Dist1 = Measure.MinimumDistance("Cylinder:1", "CylinderFace", "Piston:1", "PistonFace")
Dist2 = Measure.MinimumDistance("Cylinder:2", "CylinderFace", "Piston:2", "PistonFace")
dave.cutting
Could you use annotations and apply a dimension for you stroke?
Dave Cutting
James_Willo
Here is the method I mentioned above.
James W
