Is it possible to create a self-adjusting sketch symbol?
Francisco_García
Mentor Mentor
Francisco_García
Hi, folks.
Does anyone know if it is possible to create a sketch symbol composed of variable text and a shape that contains it, so that, just like with numeric references, the shape automatically adjusts by growing or shrinking according to the text length?
Fco. García Bayarri
Delineante industrial | Formador técnico
LinkedIn | YouTube | Twitter | Telegram
Por favor dame Kudos y marca esta respuesta como Solución Aceptada si responde a tu pregunta.
Please give me Kudos and mark this answer as Accept as Solution if it answers your question.
Alexander_Chernikov
This can be partially done using iLogic, but each new designation requires a separate sketch symbol
(object dimensions cannot be changed for different occurrences of a single definition).
The attached files (in IV2023) contains an example of such rule (it also added separately in text format) for several definitions of sketch symbol.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Francisco_García
Thank you, @Alexander_Chernikov
Fco. García Bayarri
