Can I mark a parameter as "Key" and "Export" within Excel when linking?
chris
chris
I'm looking to try and mark parameters as "Key" and "Export" from an Excel file.
I get the the columns are in order as the following:
Parameter Name, Value, Unit, Comment
but does Autodesk allow us to also set "Key" and "Export" and if so, which column and what order are they and what is the value for each?
pcrawley
I think that's a "no".  Form the documentation, only 4 properties are supported by the link: Name, Equation, Unit, and Comment.
In the API they are available as ExposedAsProperty and IsKey - but that doesn't help your Excel linking problem.  Do you have many parameters to import that have these settings?
Peter
