Is iLogic Design Copy not supposed to change file references?
YannickEnrico
Advisor Advisor
YannickEnrico
So I've been using iLogic design Copy to make new project files for similar (although not identical) projects.
I think in IV2024, it did replace file references to the new files that it copied, but it appears to me it doesn't in 2026.
Am I wrong about behaviour in 2024, or is the behaviour in 2026 wrong? I don't see a checkmark to enforce updating of references, although it would make sense to me that a copied drawing along a copied part would reference the new part, and not the old part.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
MjDeck
@YannickEnrico , yes it should update the references. But there was a problem with this in the 2026 release. We fixed it in the 2026.0.1 update. Please install that.
If for any reason you can't install the update, there is a workaround that you can apply to the 2026 release.
Mike Deck
Software Developer
Autodesk, Inc.
