Is 4k monitors suitable for inventor 2021 and Vault 2021
mikko_leppala322U9
mikko_leppala322U9
I need to get new monitors for Inventor 2021 and Vault 2021. I also have Autocad 2024 and many other programs that I need daily. (2x outlook, 2x Teams, multiple browsers, BC365, Navisworks, etc.)
I planned to get 3x 27" 4k monitors, but there seems to be some issues running Autodesk products at 4k (Vault at least).
Does someone have one or more 4k monitors and running them flawlessly? Does 27" 4k make text and icons too tiny?
Or should I get 3x 2560x1440p monitors?
I also need new laptop to replace this ancient workstation, but that is another story.
Looking forward for your replies!
Gabriel_Watson
You might have to select Compatibility > Change High DPI settings > Override high DPI > System (Enhanced), under Properties (right-click the app shortcut to pick that).
Similar thread with more on this:
https://forums.autodesk.com/t5/inventor-forum/how-to-fix-a-4k-window/td-p/9396727
mikko_leppala322U9
Thanks for your reply Gabriel. Do you run Inventor and Vault at 4k?
