Is it possible to have the ipt sketck dimensions visible once its put on an idw ? I am able to turn on model sketches but it doesnt show the dimensions from the sketch.
Thanks Jamey
Jamey,
Don't know if this is what you are looking for or helps you, but you can retrieve dimensions from your model in an .idw here.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi! I am not aware of a way to display or retrieve dimension from unconsumed model sketch in drawing. You will need to create a feature based on the sketch so the dimensions can be retrieved.
Thanks!
