IPT file save as issue
Hi everyone,
I'm writing for asking to Autodesk community a solution to my problem.
I received an Inventor 2013 IAM file,I need to open an IPT file component and saving it with a new name.
So I open the IPT file and used "SAVE AS" and changed the name... The problem is this:
Inventor create the new file in the specified folder with the correct name... I closed the old IPT and open the new one.
The new IPT show me the previous part-name at the top of part-tree and the same on Windows window near the application name ( see pictures below)
If I check Iproperties all is good, the part-ID, part-name, file-name are correct.
Does anyone have a solution?
I'm trying to fix this with SP2 UPD6 but I'm downloading it.
Thanks for any help!
Best regards
Matteo Rossi
-niels-
Welcome to the forum!
Not sure if this will work, but try slowly doubleclicking the incorrect name in the browser.
(so you can edit the text)
Then delete the entire name and hit enter, that might reset the name.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
salariua
In parts and assemblies deleting and hitting enter fixes it, for drawings you need to put a space and then hit enter.
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
