iProperties from Parameters with iLogic
- I have a part containing five solidbodies.
- lets call them a, b, c, d and e
- I have then split these five solidbodies into five separate parts
- I want to change the "part number" and "description" in each individual part iproperty to link into the parameters from the original part
- I can link certain parameters (ie. dimensions) quite easily
- but not multi-value text/number parameters (ie. anything with a dropdown list)
Suggestions?
Using 2016 version.
andrewiv
You are correct.  There is no way, that I know of, to export text parameters.  You can, however, export multi-value numerical parameters and keep them linked.  If you want to link a text parameter, you have to writ a rule to read the parameter and create an iproperty with the same value.  You could set this up to run as a manual operation or you could use itriggers to run it automatically after a certain event.
Andrew In’t Veld
Designer / CAD Administrator
Thanks Andrew - could you provide a quick example?
andrewiv
Here is a quick example of how to create the iproperty.  TEXT_IPROPERTY is the name of the iproperty you want to create, TEXT_PARAMETER is the name of the parameter you want to read.
iProperties.Value("Custom", "TEXT_IPROPERTY") = TEXT_PARAMETER
Andrew In’t Veld
The TEXT_PARAMETER is to be taken from a different part, from which I am unable to link text currently.
ie. dependant on the requirements - the iproperty of the part needs to read either "RFSO" or "RFWN" from the solidbodies I created the part from.
Hope that makes sense!
