Is there a way to have different members with different material thicknesses?
Solved by mcgyvr. Go to Solution.
In what way?
in the same part?
In the ipart table go to the "sheet metal" tab and double click the physical entity that corresponds to the sheet metal rule.. That will put a dropdown into the table and allow you to select other sheet metal rules (thicknesses)
