Inventor Forum
IPart suppressed sweep 3D sketch failure
5 REPLIES 5
523 Views, 5 Replies
I have an Ipart I created and in some of the parts there is a swept feature. In other configurations it is suppressed.
The issue is that the 3D sketch for the sweep gets broken going to/from the configuration. The path is generated from an extruded cut that is also supressed.
I tried to recreate the sweep using a different sketch, but that wasn't successfull.
Is this a bug or is there a different aproach I can use?
5 REPLIES 5
NicolasXu
Hi Mech.Mon,
It sounds you need the 3D sketch available after some other features (extruded cut, sweep) suppressed?
I’m thinking it depends on how the sketch was generated. Without looking into the model, it’s hard to say where the problem is. Could you post the dataset or more information that may help me reproduce this problem here? You can also send it to me via email (lixiongDOTxuATautodeskDOTcom)
Nicolas
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Tags (2)
NicolasXu
in reply to: NicolasXu
Hi Mech.Mon, I received the dataset and replied email to you. Please let me know if any further questions. Thanks, Nicolas
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
Thanks Nicholas,
I did a similar trick, but I must have missed a constraint becaus my projected sketch went haywire. So After I get a chance to to figure out where I went wrong, I'll do a write up later today, and post it here for posterity.
Mon
Nicolas,
I found my error, when I was selecting the path I had selected an edge, not the curve.
This demo shows a simplified version of what the solution is:
#1 when selecting a path for a sweep that will be suppressed use a curve instead of an edge.
#2 Make sure the sketch of the curve is visible before begining.
Mon
NicolasXu
Hi Mon,
Glad to see you have figured it out. It's a little tricky as the edge is easier to be selected than the curve.
Nicolas
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
