Inventor Forum
iPart in Assembly, How to change configuration
5 REPLIES 5
7740 Views, 5 Replies
Greetings, I have created an iPart which has a left and right configuration. I already have the default configuration placed in the upper level assembly, how do I change the parts to reflect which configuration I want to show, either left or right? Do I need to delete out the current parts and replace them in the configuration I need or is there a way I can do it without deleting them from the assembly?
Thanks!
Justin
Thanks!
Justin
5 REPLIES 5
Mark.Lancaster
Mark.Lancaster
Justin
It sounds like your trying to create an iAssembly, is that the case?
Mark Lancaster
Justin
Mark Lancaster
in reply to: Mark.Lancaster
Yes Sir that is the case.Robot Frustrated
Mark.Lancaster
Mark.Lancaster
Once I place my iPart and create my iAssembly I can do a table replacment
Mark Lancaster
Mark Lancaster
mcgyvr
mcgyvr
2 ways..
Either through the iassembly table (using "table replace")
Or switch from factory scope to member scope (manage tab/author section dropdown). Then switch to the member you want to edit then expand the ipart to show the table node in the model browser and right click on the table icon and select "change component"
There are a few videos on youtube that are great at showing all this..
here is one to watch..
https://www.youtube.com/watch?v=2t6zjWBguys
2 ways..
DRoam
DRoam
If you're just trying to get the new iPart version of the part into the assembly, you can just use the Replace command. It's under the "Assemble" tab -> "Component" panel. Inventor will try and keep any constraints you have. You can select the "Tree" tab when placing to select which configuration you want.
From there, if you want to change the configuration, you can go to the part in the browser tree and expand it, then right-click "Table" and choose "Change Component".
