Has anybody else noticed when you have a pull-down cell in an iPart or iAssembly table in Inventor 2015 that you have to pick like 2 or more times to get the pull down to work.
Inv 2015 Pro/Win 7
Yep.. see it here too
The first click just gives the cell focus.. The second click starts to open the dropdown list then it snaps back closed. The 3rd click finally opens it.
Thanks for reporting the issue guys. It has been tracked and under investigation, will keep you updated on the solution.
Amanda
I have this issue as well...and it is extremely annoying as our ipart tables cant contain well over 100 cells...makes the process very time consuming now. I have also noticed that I am unable to highlight any colums other then the first one, even though i get the down arrow appearing when on the column header. I click and the column turns black only when I click, but does not stay highlighted...so I can no longer copy and paste columns, which makes the process take EVEN LONGER!!!! COME ON AUTODESK!!!!
