Inventor Forum
iPart/iAssembly index digits
5 REPLIES 5
520 Views, 5 Replies
Hello
there is a possibility to set the default index digits to 3 for Part Number and Member Name on iPart/iAssembly options? (see the image attached)
I want to use this setting inside a part/assembly template.
With many thanks
Labels (2)
5 REPLIES 5
Forgot the image
johnsonshiue
Hi! Unfortunately, I don't think so. The settings are hardcoded defaults. iPart/iAssembly was designed to generate library components. Are you creating a lot of library components?
Many thanks!
Software Test Engineer
lena.talkhina
Hello @Anonymous  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
in reply to: johnsonshiue
Hi @johnsonshiue
and thank you for your feedback. We use the iParts and iAssembly intesively for manufacturing components/assemblies and our member's version need 3 characters to be defined.
I mean our manufacturing codes are like code-001, code-002, code-003
In this case when need to create the members name need to always set up the table style.
There is a method to figure out a solution?
johnsonshiue
Hi! The only way to do that is to formulate the member names in Excel (edit the table in Excel). There isn't much customization allowed in iPart/iAssembly table editor.
Many thanks!
Technology Administrators
