ipart generate files error
Rangav7
Rangav7
i have a stock ipart file.
if i copied this stock model ipart and renamed the ipart in table.
am not able to generate files in table. it is showing this error message.
please help.
Mark.Lancaster
IT sounds like there's some value or values in the ipart table that is incorrect, so the features that use it are failing.  I would check your dimensional values.
Mark Lancaster
Rangav7
if i copied and didnt changed the file name in table. i can able to generate files
but if i changed member and part number names. i am getting this error
Mark.Lancaster
Attached the failing ipart here and specify which version of Inventor you're using.
Mark Lancaster
