Inventor Forum
Ipart changing folder problem
2 REPLIES 2
M_Santi
101 Views, 2 Replies
I want to change the location of the model and the configuration model of the ipart.
The problem Im having is that the "reference document [file location] cannot be resolved. Please open document [file location] and resolve it before using it in the drawing."
It would say the quote above when I try to add the model in a drawing.
Is there a way solution to this without using ilogic?
2 REPLIES 2
M_Santi
in reply to: M_Santi
I found the solution myself on what was causing it. It was causing it because the file itself did not have a factory member when transferring. To fix this you will need to generate a file on one of the Ipart configuration. I couldn't do it before because the file name was too long and it was adding all the parameters from the file. Is there away to generate a file and not include all of the parameter to generate the file while keeping it?
Frederick_Law
Filename is set in the iPart table.
