iPart - Adding a calculation to the spreadsheet
isocam
isocam
Can anybody help???
I have an iPart (for testing) that has three values.
The first two values are: ChainPitch = 50 & NumberOfTeeth = 8.
I need the third value (shown in yellow) to be calculated using the formulea: ChainPitch/SIN(PI/NumberOfTeeth)
Is it possible to add the above calculation to the spreadsheet in the yellow column?
Many thanks in advance!!!
Darren
imajar
Set up the equation in the parameters first, then it will automatically fill in the ipart author and work.
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
johnsonshiue
Hi! Another approach similar to Aaron's is to link the cells in Excel. Edit the table in Excel and write the equation by linking columns.
Many thanks!
Software Test Engineer
