hello everyone , When i tried to make an involute spline in inventor pro i found the OK button is Usally off
Can any one help me ??
i attached a pic. to indicate the problem .
Solved by johnsonshiue. Go to Solution.
Hi! There is a bit usability issue here. The command assumes that you have a shaft and a hub ready to create a matching gear set. But, in your case you only have the shaft. So you just need to depress the button on the right in "Select Objects to Generate" section in the dialog.
Thanks!
Thanks!
oh, thank you very much , you really helped me
thanks again 🙂
thanks again 🙂
