Involute Spline Editing
matt.murray
matt.murray
Hello all,
I have an internal involute spline I am trying to generate geometry for. The criteria it needs to meet is:
Fillet Root Side Fit Class 7
PA 30
Pitch 32/64
Teeth 10
Form Dia. .348
Base Dia. .2706329
.379 Major Dia.
.3125 Pitch Dia.
Circular Space Width
Effective Min = .0491
Actual Min = .0539
I am able to generate the spline inside Inventor 2021 with the only discrepancy being the Major Dia. as shown:
Internal Involute Spline Data
ANSI B92.1 - 30 deg, Fillet root, Side fit
Number of TeethN10.000 ul
PitchP/PS32.000 ul/in/64.000 ul/in
Pressure Angleα30.00 deg
Base DiameterDb0.271 in
Pitch DiameterD0.313 in
Major Diameter, InternalDri0.369 in
Form Diameter, InternalDFi0.348 in
Minor Diameter, InternalDi0.281 in
Max Actual Circular Space Widths0.054 in
Min Effective Circular Space Widthsv0.049 in
Max Measurement Between PinsMi0.242 in
Pin Diameter, Hubdp20.054 in
Is there any way for me to modify the major dia. to create the appropriate geometry?
Thanks!
WHolzwarth
I only could do it with some manual work. 2020 files in Zip
Walter Holzwarth
matt.murray
Wow, that is fantastic! Thank you! I need one more modification, the Minor Dia. needs to be .2865. Can you explain how you manually edited the initial spline to provide the file?
Thanks!
WHolzwarth
Hi Matt, here's the updated file. I didn't change the involute spline itself, but only did a replace face operation at the major dia, and a trimming at the minor dia. Adding fillets, splitting for only one tooth and patterning it all around.
Just move EOP up and down step by step. Most of the workflow is self-explaining.
Walter Holzwarth
