This seems to have happened due to some kind of interaction with the QuickViews Add-In, but this has never happened to me until yesterday. All of a sudden, I have two title bars/window borders, and none of the buttons or hotkeys work.
Any ideas why this is happening, and how I can get Inventor working again without having to close out and restart? I can't save (even with hotkeys), and so I have no way of preserving unsaved work.
Solved by johnsonshiue. Go to Solution.
Hi Matthew,
It seems to be Quick View related. If the Add-In is unloaded, does the problem go away? Maybe you want to try the followings and see if it helps.
1) Go to Windows Display Settings and select the recommended scale and resolution.
2) Right-click on Inventor desktop icon -> Properties -> Compatibility -> Change High DPI settings -> check both boxes.
3) Go to Control Panel -> System -> Advanced System Settings -> Environment variables -> create "QT_AUTO_SCREEN_SCALE_FACTOR” and set it to 0.
Many thanks!
I only did the first two things you suggested, but I haven't had this happen since so I believe that fixed it. Thanks!
