Inventor Forum
Inventor window becomes 'floating'.
2 REPLIES 2
NigelHay
229 Views, 2 Replies
This is probably something I am doing wrong but it is annoying.
Every now & then, when I have multiple Inventor files open, I click on one of them to bring it to the front & it becomes detached as a separate floating window. It now does not appear as one of the files listed in the Inventor task bar at the bottom of the screen & I can't seem to persuade it to return there. I've tried clicking the 'return to previous layout' button but my only option is to close the file & reopen it.
I think the problem starts if I slightly drag the mouse when clicking on the file in the task bar but, as I am quite clumsy, that will keep happening.
2 REPLIES 2
talha.tufan523TD
in reply to: NigelHay
like this i think you must drag and drop the bottom side (1 to 2 )
Good luck.
NigelHay
in reply to: talha.tufan523TD
Thanks, that works. When I drag the bottom edge it reattaches to the task bar & shows the file in a split screen with whatever I was looking at before. I can the maximise the file view & everything is back to normal.
Technology Administrators
