Inventor Welding Symbol error
JSklenars2R39D
Message 1 of 13
JSklenars2R39D
Our welding symbol style has gone wonky. The 'x' which was a '-' has moved to beside  the weld type symbol. If I open an older drawing that was correct as soon as you change something the symbol changes to the error state and will not revert. It is suddenly affecting all our users.
check style settings with drawings that are correct and all setting are the same?
Replies (12)
Message 2 of 13
NigelHay
The symbol works OK for me (Inv2024) & appears as in your red annotation. It must be some problem in your set-up, do you have more than 1 CAD seat, does it affect them all?
Message 3 of 13
JSklenars2R39D
Hi Nigel
Yes we have 20 seats and it is happening to all of them, seems to have been since a recent update. Our template hasn't been updated for about a year and until just this week it was working fine. Even when I open an old drawing that shows the symbols fine if I add another it goes bad. There seems no way to edit these weld symbols, they are just how Autodesk has made them and that is that. With all the style settings for weld symbol you would have expected there to be a way to change the layout but not from what I can see.
Message 4 of 13
johnsonshiue
Hi! Please share an example idw/dwg here. It could be a corrupted style.
Many thanks!
Software Test Engineer
Message 5 of 13
JSklenars2R39D
I had thought it could be a corrupt style so import weld symbol from old drawing but still same.
See attached.
Message 6 of 13
JSklenars2R39D
File didn't upload
Message 7 of 13
NigelHay
I can understand the symbols not being editable as they will be based on ASME/ISO standards. Let's hope that johnsonshiue can find some corruption in your files.
Message 8 of 13
mgrenier1
My guess would be to check the ribbon in tools/document parameters and the standards tab and try to switch it to ANSI or something
Message 9 of 13
johnsonshiue
Hi! Many thanks for sharing the file! I took a quick look at the custom Weld symbol style. There isn't anything apparently wrong in terms of the actual settings. It seems strange to me that an ANSI-based style does not contain the dashed line. My limited testing shows only non-ANSI standards like DIN, ISO, or BSI do not contain the dashed line.
Does this behavior just start? How was the style created? Has it been migrated?
Thanks again!
Message 10 of 13
JSklenars2R39D
Back in the day Inventor use to come with all the standards, so we just migrate every couple of years to the new version of Inventor. The ANSI weld symbol has been fine for the last 10 years and only recently it went bad. ANSI is what we use in Australia so I need to working again. How do I raise this with AUTODESK I could see a way to contact them for this type of issue?
Message 11 of 13
johnsonshiue
Hi! Please feel free to log on to manage.autodesk.com and there is a link to contact Autodesk Product Support.
Many thanks!
Message 12 of 13
HubesXB
Hi @JSklenars2R39D and @johnsonshiue  , did you ever resolve this issue? We are having the same issue in Inventor Professional 2025.3.2.
Cheers
Message 13 of 13
hkilic896XF
Hi.
In IDW documents I see that
if I want to add drawing welding symbol to the beads that exist (or visible) on the cross section of view, I can not set "Sync Preset" to the bead, even if bead has a model welding symbol.
Is the functioning like  this or am I missing something?
