Announcements
Inventor VS Tekla For Facade And Curtain Wall Design
Hi there,
I was wondering if any one has used Tekla and Inventor for facade and curtain wall design? i would like to know which one is better in terms of modelling time and efficiency, out put(bill of material with material property), 2D drawings(fabrication and shop drawings with details to be added in 2D environment etc) and any other comparison you think is fit to understand which one is better for the above mentioned jobs.
Thanks and regards.
kelly.young has edited your subject line for clarity: Inventor VS Tekla
Replies (7)
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
You can also create curtain walls within Revit:
Revit: Create a Linear Curtain Wall
Inventor can pretty much create anything, but it depends on what you want to do with it and if it is the right program for your end goal.
If you can provide a bit more information of the scope of design and intended use that might clarify what is the best software tool to use.
Please select the Accept as Solution button if a post solves your issue or answers your question.
 HI @kelly.young, Thanks for the welcome.
 I have already been using Inventor for the past 3 yrs so i am aware of most of the capabilities of inventor, but since i might need to use tekla in the office from now own, i would like to have a comparison between the two soft wares in regards to Facade design, in order to facilitate the decision of weather we should get tekla or not.
the kind of design or modelling is mostly extrusions, glass, accessories etc. and the general geometry varies from a simple curtain wall to more sophisticated envelope with 3D Curves etc. the model stage is supposed to be all through the design stage and with final outcome of fabrication 3d models and also some 2D drawings. also i would like to know if tekla has a tool similar to  "I-COPY" in inventor.
I hope this is more clear.
thanks and regards.
S_May
@Anonymous,
do you have experience with i-copy?
https://knowledge.autodesk.com/profile/contributions?rt=1528189168749#/dashboard,
Please search here for i-copy, there are good examples, this is also possible with disguise.
2018-06-05 11_03_11-Contribution Dashboard _ Autodesk Knowledge Network - Internet Explorer.png
kelly.young
Autodesk Support
Autodesk Support
@Anonymous thanks for the additional info. With that much experience I think you would be ready to move towards some advanced features within Inventor to achieve what you are trying to do.
After a quick search @Anilc posted a good screencast example of a workflow for curtain walls:
Some good links to iCopy and general info:
Curtain Wall Workflow Resources
Depending on what approach you want there is:
iLogic
Frame Generator
iParts
Modeling Techniques
Just found this pretty cool when searching:
Autodesk Inventor solves a 15,000 piece glass jigsaw
to reply on the screencast, why you guys are not using frame generator for the same process?
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous welcome to the Autodesk Community!
You could also use Sweep. It will remain a single body so you would have to create diagonal planes for the mitred corners and Split.
Frame Generator would work well, it creates an assembly with members. It really depends on your needs and if you want to do a Multi-body Part.
Many ways to go about designing the same thing!
    Do you draw Curtain wall with the  frame generator?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
