I've seen this problem with several fonts (actually every one I've tried so
far). Our template uses only Arial with various sizes (.06", .08", .09",
.1", .12" etc.) This also occurs when trying to use every printer we've had
here (Canon 3300 photocopier, Konica/Minolta bizhub C351 photocopier, an HP
LaserJet 5000, an HP LaserJet 5500 and a Xerox 8830 wide format plotter)
The first time I saw this and realized the extent of it I couldn't believe
it took so long for us to discover this problem. For that reason I haven't
been forced to find a solution, if we need to send out printable file we
just use PDF or DWF.
For some reason I don't think it has to do with fonts or printer drivers, I
think it it software problem. Josh, if you get a free moment could you
confirm this problem? just open an idw with Inventor View and print it to
see what happens?
thanks,
Lon
