Hi.
The matrix on Inventor view 2019 shows that it is possible to measure.
I have now downloaded the 2019 version - and i dont see how to measure.
Please have a look:
https://www.autodesk.com/viewers/all-viewers/compare
Is it possible to open an .iam in a given project .ipj. (still in inventor Viewer 2019)
I only see a project editor.
But if i cant assign a project file, then its almost impossible to open a .iam drawing (without any errors!)
Is it simply not possible or what?
Solved by johnsonshiue. Go to Solution.
Solved by Xun.Zhang. Go to Solution.
How about leverage Inventor view for a Pack & Go file? the Inventor view more like for the viewing when sharing data, if it's true, you have to do Pack & Go first.
Regard to the measure , I don't see the measure tool as well, will contact project team for a better understanding then, please stay tuned.
Hope it helps!
Well....you are right, but in my case i am working on that single project in maybe a half year.
And during that periode the salesteam should be able to open the newest drawing everyday.
I am not going to pack and go on daily basis..:-)
So i would be very nice simply to assign the project file and then just open the most recent .iam drawing.
Yeah, agree.
Could you please submit a new idea in ideastation to gather more supports?
By the way, it might not be that simple for coding.
The measure is not supported in Inventor view, working on correction in short for the description soon.
Thanks!
Hi! Indeed, Inventor View does not support measurement. The information on the comparison chart is wrong. I will work with our project team to correct it.
Regarding ipj file, you should be able to browse to a folder and activate a project file. I don't understand what you meant by you can only work on single project. Did you download Inventor LT or Inventor Pro or just Inventor View?
Many thanks!
You are right about activating projects - didnt work yesterday - today it does - Thanks.
By working on only one project for a half year I ment that i am drawing on that single project all half year.
Not that im not able to work on serveral projects.
Thank for you're reply
Lars Christensen
What is discussed in the beta forum can not be talked about or referenced in the open forum.
Those types of discussion must take place in the beta forum topics and not here.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hi Lars Christensen,
A quick update, the content is up to date now.
Thanks!
