We upgraded recently from Inventor 2016 to 2018. Next step is to migrate all content in the Vault, starting with the Content Center files. To be able to work with Inventor Task Scheduler and Vault content center files, we created a CC project file.
The issue I experiance is this:
After migration Task Scheduler was unable to check in the CC files
I started a manual Check in job and found out that the job wants to check in the files to a wrong folder..
How to solve this??
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
Under your Vault tab in Inventor, did you properly map the folders between Inventor and Vault?
Mark Lancaster
& Autodesk Services MarketPlace Provider
