Inventor Using 3d Connexion Space Mouse Has Jumpy Jerkiness On Rotation
creocatia3d
Message 1 of 14
creocatia3d
how do I leave my workspace equal to the assembly environment? I would like to see the settings that are enabled in assembly mode to leave the same in common part. I'm very slow in turning the piece in by the ordinary. In the assembly is excellent.
* I have 16GB of ram and 3 mega video card
kelly.young has edited your subject line for clarity: video ownership
Replies (13)
Message 2 of 14
Mark.Lancaster
@creocatia3d
What?  Your posting is not clear.  What are you trying to accomplish?  And what does this have to do with video ownership?
Mark Lancaster
Message 3 of 14
kelly.young
Autodesk Support
Autodesk Support
Hello @creocatia3d are you trying to create a Presentation.ipn or working within the Inventor Studio Environment?
Are you wanting it to be the Realistic Ray Tracing view that you see in the viewer but don't get that from the video export?
If you could restate what you're trying to do and show any screenshot or record a screencast would be helpful.
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 4 of 14
creocatia3d
image "jumping".
environment IPT
Message 5 of 14
kelly.young
Autodesk Support
Autodesk Support
@creocatia3d so when you are in the Part environment the model is jumping when rotating but in Assembly environment it is fine?
Have you installed the most recent Inventor Updates?
Is the Graphics Drivers up to date from the manufacturers website?
Did you somehow check something in the Application Options > Display or > Hardware?
If you have run out of options you can always try Reset Utility or Repair Install.
Message 6 of 14
creocatia3d
I already updated 2019. if I open a piece here from the forum, it gets good too. the problem is in the inventor's default. So the question is how to compare the settings of my software and another file.
Message 7 of 14
DarrenP
can you  provide a screenshot or a screencast of what your seeing?
your postings make no sense
DarrenP
Message 8 of 14
creocatia3d
attached....
Message 9 of 14
kelly.young
Autodesk Support
Autodesk Support
@creocatia3d it looks like you're using a space mouse or something similar, the screencast doesn't show much lagging during the rotation, what exactly is the issue that you are seeing?
Does the face or line selection not behave as you like? Still not sure as to what you are trying to show.
Message 10 of 14
evertonuli
Yes, I'm using 3dconexion.
I wish the swivel, movement would be smooth without traces or jumps.
The assembly environment is smooth. In IPT mode, keep these jumps
Message 11 of 14
evertonuli
See that it seems that the piece is in my hands
Message 12 of 14
DarrenP
still got no clue what your trying to show
you provide no description of what is going on in your screencasts
DarrenP
Message 13 of 14
Rory_M
The jerkiness can be caused by "ambient shadows" being switched on.
See the attached image and turn this setting OFF to make things smoother.
Message 14 of 14
creocatia3d
Perfect!!!!!!!
Thanks!!
