Inventor Forum
Inventor Tolerance Feature
2 REPLIES 2
581 Views, 2 Replies
I'm adding PMI data to a part but I can't select the same face of the part twice, why is that ?
Thanks in advance
Labels (3)
2 REPLIES 2
johnsonshiue
Hi! I guess selecting a face twice would not help locate a tolerance feature. Please share the file here. It could also be a bug.
Many thanks!
Software Test Engineer
in reply to: johnsonshiue
I was using the Tolerance Feature and then selecting faces for a slab or slot tolerance. When instead I should've used the Dimension feature to achieve it. My bad.
Thank you for your response !
