Inventor Forum
Inventor to Revit
4 REPLIES 4
nwe.nwe
447 Views, 4 Replies
Inventor to Revit
nwe.nwe
Hi Dears,
I have been tried to export from Inventor to Revit by using BIM building components work flow type -
assembly (.iam) :right_arrow: part (.ipt):right_arrow: .adsk:right_arrow: .rfa.
After successfully exported and Translation report is fine too ,
When I tried to open this .adsk file from Revit  via building components, it appears only bounding box .
Even after changing  "fine" in detail level and "wireframe"in graphic display option of Revit setting , still show the square box. Of course , after loaded family (.rfa) file into Revit project file , it shows hollow box only.
But , above exporting work flow worked successfully for some models.
Could someone help me to solve this issue ,please?
Kindly refer to attached screen shots.
Thanks in advanced.
Inventor to Revit
Hi Dears,
Thanks in advanced.
Labels (1)
4 REPLIES 4
Xun.Zhang
in reply to: nwe.nwe
Xun.Zhang
Hello @nwe.nwe,
Could you help send us the file for more investigation via email xun.zhang@autodesk.com?
It seems a defect to me.
Thank you!
Xun
Hello @nwe.nwe,
Thank you!
Xun
nwe.nwe
in reply to: Xun.Zhang
nwe.nwe
Hi Xun.Zhang,
Thanks!
I will send you the file via mail.
Hi Xun.Zhang,
Thanks!
Xun.Zhang
Xun.Zhang
Hello @nwe.nwe ,
By checking the adsk file (re-exported from Inventor 2021) in Revit, it seems a layer case, please delete the boundary layer and everything is fine.
Hope it helps!
Xun
Hello @nwe.nwe ,
Hope it helps!
Xun
nwe.nwe
nwe.nwe
Hi Xun,
Thanks for ur help.
But my case is ,nothing  appears inside this bounding box .😅
Pls refer attached two images and right image is successful one.
When it was loaded into rvt project, bounding box dosen't bother.
Both are exported from Inventor 2014 and open in Revit 2019.
Thanks!
FailFailSuccessfulSuccessful
Hi Xun,
Thanks for ur help.
Thanks!
